Back Wheel Not Turning
Geoffrey Davis /
Hello I've taken apart my Za50 to flip the clutch and change out the pucks. After doing this I put the engine back together but my back tire will not move now. I've taken it back apart two times (it moves while the engine is apart) but once I throw it back together the tire once again doesn't move.
Any ideas would be great.
Re: Back Wheel Not Turning
hmmm.... I'm guessing you did it wrong
did you put the chain back on?
release the brake
mur info?
Probably Fred /
Clutch preload not right?
Not shimmed correctly?
