Re: Can't get 14mm variator bolt off the bell. Av7
Rebel Moby /
Look in the ring grooves, you will see a pin in each of the grooves, the pins are towards the front of the motor not the back.
If the rings are sticky in the grooves you need to clean the carbon out of the grooves. If the rings look worn or have marks on them then replace them
