Re: Can't get 14mm variator bolt off the bell. Av7
Jordan Guest /
Thanks so much! The wood trick worked great with loads of blaster and heat. The drum is kinda stuck like I expected so it's getting heat soaked now since my puller didn't get it on the first try. On my way to rebuilding now
