Re: Can't get 14mm variator bolt off the bell. Av7
Rebel Moby /
The grease nipple must come off in order to use the puller, but it does not need to be removed to get off the 14mm nut.
If it is this much of a fight you might find the clutch cover extremely tight and you would need to heat soak the assembly before being able to remove the cover with the puller.
