Re: Can't get 14mm variator bolt off the bell.
Mel Dyer /
If you don't want to risk damaging the rod, you can use chain style vice grips to hold the clutch and it gives you leverage to pull against. available at harbor freight cheap. they work good on flywheels too! and if I remember right, the grease nipple does have to come out first.
