Re: Can't get 14mm variator bolt off the bell.
Rebel Moby /
I would suppose that is a AV7 you are working on, wrist pin off so obviously the jug is removed and the motor is off the bike.
You can stop the crank from rotating with a 1/2 inch bolt through the small end eye of the con rod and two blocks of wood on each side so the bolt resting on the blocks will stop rotation. Dont use any bolt with a smaller diameter then 1/2 inch or there will be too much stress put on a small area of the eye and it can distort.
Only use a 6 side socket on either 14mm nut or the grease fitting.
You can put a impact gun to the 14mm at this point, use an impact driver on the grease nipple if it is defeating your attempt.
