78 express fuel leaking from overflow tube
every since i put a inline fuel filter on my express as soon as i turn the gas on it starts draining out the overflow tube any ideas on why this is happening. also i need the filter due to how rusty the tank was
Re: 78 express fuel leaking from overflow tube
Float valve not sealing because of the rust or the drain screw is not sealing well and letting the gas just flow out.
jake finley /
ok ill take carb apart and look at float its not the drain screw because i tried another bowl.
Either the float needle isn't seating or the float may have a hole in it, allowing it to sink.
