How do you shorten a cable housing
How do you cut a cable & housing that are too long without crimping the end of the housing so the cable won't fit through?
Re: How do you shorten a cable housing
Emil Kniemel /
cable housing cutter.
Luke “Funkenet” Hosfield /
I just cut it with a wire cutters. Crimping at the ends has never been a problem.
If it does crimp the ends just stick a nail up in there to clear the passage.
Emil Kniemel /
i use a little cut wheel on the end of my dremel. i use it to cut the cable as well. works perfect.
John Joedicke /
+1 on the Dremel cut off wheel.
