1980 Vespa Grande
I bought this Grande...having trouble getting it to run, has spark,has gas...is there a specific plug for these? need some suggestions, Thanks.
Re: 1980 Vespa Grande
b7hs
filthy jake /
You are the man whom I've heard alot of lately. I'm friends with mike, I'm gonna get the plug tomorrow. Thanks Leo, I appreciate it.
maybe?
i*m over here in KCMO, Waldo
spark, gas?
bet your main jet is clogged
got an old set of Vespa Grande tires if you need them.
cheap
Adjust the points to 0.45 mm, unclog the jet with a thin steel wire and some carb cleaner, make sure you're getting compression (take the spark plug out, put your thumb over the hole, and crank it -- if it pushes your thumb off you're probably good). If it's still not working try spraying some carb cleaner or starting fluid in the spark plug hole.
It's got excellent compression. Cleaned the jet with a guitar string and flushed the fuel line. Float bowl was spotless. Its getting spark, but its orange... Plug not hot enough? Brand new b6 in it, gonna swap with a 7 and get back with ya.
if you've got weak spark you condenser could be shot.
