'06 Streetmate won''t start
Kevin Guerrero /
The other day the screws that connect the exhaust to the cylinder head completely came off while riding. I decided to take the gasket head off and noticed the gasket was shot and the piston ring was as well. I bought the parts and installed them. Everything went smoothly. When I go to kick start the bike, its fairly tough. It wont start at all now. It used to start on one pick. Any ideas?
Re: '06 Streetmate won''t start
Kevin Guerrero /
So I take it apart and this is what I see. I guess a new piston is what I need?
Yep, new piston. How is the cylinder?
Kevin Guerrero /
The cylinder is fine. Looked unharmed from what I can see.
Where would you recommend buying the piston? I have a 70cc kit so I would need the 43mm correct?
Tal Reznikov /
uh, what kit? some are 44 some are 45.
it looks like somwthing got into your piston, do you run an air filter?
He broke a ring and put a replacement ring on. He probably didn't clean out the crankcase and had a chunk of broken ring in there that got picked up and went into the piston.
You have a piston port A55, yes? If so, this is what you need:
https://www.treatland.tv/airsal-44mm-replacement-piston-p/tomos-airsal-piston-a55-44mm.htm
