Does anyone have pictures of their Derbi PP rebuild?
I've had this piston port taken apart and floating around for a while, now I'm kind of unsure of where some of these shims go. Maybe you were more responsible than me and took pictures of that stuff though? Or does anyone have a piston port manual different than the one in the wiki? That one sucks and it's for a later model or something.
Re: Does anyone have pictures of their Derbi PP rebuild?
hey man
i*m splitting my PP cases this weekend.
if i can get my camera to work i will post/send pics to you.
there should only be 2 or 4 shims
campeona del mundo /
heya 1980 sl buddy i only have one picture...hope it helps
Hey Will that picture actually does help, thanks. And Leo that would be really amazing if you could do that for me, this thing is driving me crazy.
+1 cause i did the same thing haha.. please do that leo!
man, thats a great picture
ok
will try
got everything to split the cases
this is the 3rd time anyway so its not intimidating anymore
just annoying
yeah fucking up the shims is a bummer. thought i had it down but i mixed up the one on the end of the double needle bearing and had to split the cases after closing em up once. The stress from splitting and re joining the cases with proper shimming caused my vario side bearing to blow after 200 miles. such a bummer!
freeze the crank with dry ice
heat the bearing inside edge with a socket and
a propane torch(crank bearings only)
that the trick....no stress
slips right on
tap with a plastic mallet
Ok so I made this so you guys could maybe help me a little easier. These are the shims and the places where I think they go. The pedal engagement stuff has been removed but that won't affect the shims. Is this right?
A is 16x25x1 mm
B is 16x25x1
C is 16x32x1.75
D is 16x32x3
E is 16x32x3
Oh and that really sucks Will, trying to avoid that!
question?
does one of those shims go on the outside of the case?
like on the variator, to keep the inside variator cheek
on the shaft. its way inside there, inside all the grease
@blake
@will
i wil NOT be splitting the case.
sorry
i will be trimming the piston skirt on my Parmakit piston instead
seems there is only 1mm interference between
piston and case nubs so the prudent thing to do is
trim the piston not the case
if this does not work and the piston still hits the case nubs
then i will split cases and dremel the nubs
sorry again guys
in my Derbi SLE repair manual it states there are
2 washers under the double needle bearings
looks like 1 more washer on that shaft goes on(double needle )
before the shaft with the fixed gear
hope this helps
