simpleeeeee
Will a 12 inch drum brake wheel fit if i replaced it from a 10 inch rear drum wheel, there measures enough room but is the drum brake the same size? cheers
Re: simpleeeeee
Um, it's not clear what you're asking.
Re: simpleeeeee
basically, i have 10" wheels front and back. Im wanting to replace them with 12" wheels, the front is no problem as i can sort out the disks, but i was wondering if the new back wheel, same width as the 10", would fit on, its the same amount of studs and there is plenty of room for it, i dont know how the drum works thats the problem, cheers
Re: simpleeeeee
No way of telling without trying it. Maybe if you asked on a scooter forum they would know :-P
Re: simpleeeeee
Scooter rear rims ride on a spline, so the rim will also have to match the spline on axle.
