76 garelli eurika flex igniton coil. where can i get one?
I broke the wire around the top ignition coil trying to take off flywheels. Where can I get one? Or is their a way to fix it?
Re: 76 garelli eurika flex igniton coil. where can i get one?
Whiskey Tango Foxtrot /
where is it damaged? is it the copper wires wrapping around the coil? The buy/sell forum would be your best option. I think also, there was someone who was re-wrapping coils, but I can't remember who.You could try doing that yourself, but its kind of a PIA. You need a flywheel puller, or you risk all sorts of damage.
scrap the coil, get a decent bosch HT coil off b/s.
the oe garelli coil wire is molded into the plastic, non-replaceable.
save your coil wire if it's the right length, screw it into the bosch unit.
bolt it to the frame in the same spot, run a short wire from the minus (terminal 15 i think) to the coil mounting bolt.
people have had poor results trying to reattach the plug wire to the coil, not much meat there to connect to.
