Re: !986 suzuki fa50 wont start
Jordan Guest /
Runing it in prime for long will only flood the carb. It won't hurt anything but gas will leak out like crazy from the bottom flood hole. Prime is to fill the bowl fast then switch it back to on. But if you have oil to the plug then that shouldn't be the problem
