Re: Brakes act as a kill switch.
Mel Dyer /
you're right ,I am trying to help, typical moped wiring uses the ignition ground to run the brake light so if your bulb blows the engine stops, keeping you from riding around with no brake lights. bad connections at switches, faulty switches, bad bulb socket, can all be the causes. thats why you need to test with a meter to trace down the fault. And that way you don't have to necessarily have to tear apart the harness. I apollogize(sp) if I offended you, I was just trying to make a play on words (funked ).
  Brakes act as a kill switch.Topic by: Funkenet . Funkenet . 06/02/12 02:46PM
  Re: Brakes act as a kill switch.Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/02/12 02:48PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/02/12 02:49PM
  Re: Brakes act as a kill switch.Re: Saabsonettguy . Saabsonettguy . 06/02/12 02:53PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/02/12 03:07PM
  Re: Brakes act as a kill switch.Re: Andrew Squiggman Andrew Squiggman 06/02/12 03:26PM
  Re: Brakes act as a kill switch.Re: Jimbo Grand Daddy Jimbo Grand Daddy 06/02/12 03:31PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/02/12 03:34PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/02/12 05:00PM
  Re: Brakes act as a kill switch.Re: Darrell Gabbard Darrell Gabbard 06/02/12 05:07PM
  Re: Brakes act as a kill switch.Re: Darrell Gabbard Darrell Gabbard 06/02/12 05:11PM
  Re: Brakes act as a kill switch.Re: SkUG SkUGosarus SkUG SkUGosarus 06/02/12 05:52PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/02/12 07:33PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/02/12 08:03PM
  Re: Brakes act as a kill switch.Re: CtpEDsHED . CtpEDsHED . 06/02/12 08:05PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/02/12 10:04PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/03/12 01:16PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/04/12 09:25AM
  Re: Brakes act as a kill switch.Re: Jimbo Grand Daddy Jimbo Grand Daddy 06/04/12 01:33PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/04/12 01:57PM
  Re: Brakes act as a kill switch.Re: Jimbo Grand Daddy Jimbo Grand Daddy 06/04/12 02:25PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/04/12 09:27AM
  Re: Brakes act as a kill switch.Re: nick s nick s 06/04/12 10:30AM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/04/12 10:47AM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/04/12 02:30PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/08/12 10:45AM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/08/12 11:49AM
  Re: Brakes act as a kill switch.Re: Mel Dyer Mel Dyer 06/08/12 12:24PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/08/12 12:38PM
  Re: Brakes act as a kill switch.Re: Mel Dyer Mel Dyer 06/08/12 01:22PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/08/12 01:56PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/08/12 03:53PM
  Re: Brakes act as a kill switch.Re: Dmitry K. Dmitry K. 06/08/12 05:32PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/08/12 05:33PM
  Re: Brakes act as a kill switch.Re: Darrell Gabbard Darrell Gabbard 06/09/12 02:53AM
  Re: Brakes act as a kill switch.Re: Aron Chaudiere Aron Chaudiere 06/08/12 11:00PM
  Re: Brakes act as a kill switch.Re: Funkenet . Funkenet . 06/09/12 11:16AM
  Re: Brakes act as a kill switch.Re: Aron Chaudiere Aron Chaudiere 06/09/12 11:29AM
