Re: my maxi wont GO!
Funkenet . /
Probably. Throw in a bigger jet like Roff said, won't hurt to try. Make sure to check for airleaks before you open up the throttle on it though.
Spray around the mating surfaces with some carb cleaner. If you have a leak you will notice the RPMs drop.
