F@#$@in 6v Halogen, not bright...
Hook my 6v bulb to a 6v battery and
BAAMMM.... Blind you mid day....
Hook my 6v bulb to the bike,
Horrible, really dim, like a burning ember....
Please help, its Friday.
Re: F@#$@in 6v Halogen, not bright...
John Warren IhazJawas /
make a battery box and mount tthe baterry
the battery was from my 1971 yamaha GT1. I would have to buy another battery and rectifier....
Jerry Graham /
Make sure you had a good clean ground to the lite.
I am definitely make sure I have a solid ground.
halogen cycle is very voltage dependant, a regulator may be in order.
Try revving the bike up?
so I took a headlight mount off and I reread my ground to the ground for a brand new wires on the whole system is still very dim
come to think of it I believe that my bulb that I'm trying to use comes from a d c batteries flashlight.
what kind of regulator what I need and what information would I need in order to have you help me find the regulator that I need
sweet. thanks
Halogens do want to be at the voltage spec on the bulb - or slightly above.
AC or DC they do not care much, it's a filiment. Will last longer on dc as all bulbs will.
What is the wattage of the bulb?? Also halogen tends to draw a bit more current. 18 to 20 watts may work out. But i suspect if it is a stock coil it just can't handle the load.
Put a voltmeter on the bulb and run the bike. If you see a big drop in voltage
you have your answer. Coil can not handle the load, however if it's not a big wattage bulb say 12 or 15 watts replace your lighting coil and go over ALL your grounds.
Long run...coil may not like impedance of bulb and have a shorter life - heat.
