loose pedals?
ryan fwahaha /
kinda hard to explain but my pedals are loose. if I hold one still the other has about an inch or 2 of play anybody know what I'd have to do/get to fix this?
Re: loose pedals?
ryan fwahaha /
79 puch maxi
Re: loose pedals?
Downhill Harvey (OFMC) /
Do you mean the pedal crank, No.8?
Re: loose pedals?
ryan fwahaha /
yup that's the one
Re: loose pedals?
Derek L TYTYTY /
Make sure you have nuts on the cotterpins, and make sure theyre tight. If you dont have a nut on it, bounds are the cotterpin is sticking out a little bit, just hammer it down a bit, pedal shouldnt have play anymore. Cotterpin is number 5 in that picture (edited)
Re: loose pedals?
ryan fwahaha /
that did the trick. thanks man
Re: loose pedals?
Always make sure your pedal crank doesn't move on the pedal shaft. You will destroy the pedal shaft, if it moves.
Re: loose pedals?
ryan fwahaha /
good to know thanks
Re: loose pedals?
Always make sure you pedal your pedals with your feet. because if you pedal with your hands, you are riding upside down!
Re: loose pedals?
SkUG SkUGosarus /
what if i was born with hands where my feet are?
Re: loose pedals?
ryan fwahaha /
then you'd have 4 hands and would be open to a world of handling wonders
