What do you do when this happens? (Hobbit vdo speedo cable problem)
A piece of the cable is stuck in the drive. How do I get it out? I tried using a needle and a screw to no avail. Does it come apart? (edited)
Re: What do you do when this happens? (Hobbit vdo speedo cable problem)
I tried taking one of those VDO's apart in the past with a razor. Waste of time.
The hobbit ones are crappy and use plastic gears that love to strip or break. If it's not stripped already, try a powerful magnet to pull the snapped off piece of driveshaft out.
