stalling problem, could use some help
Need some help diagnosing - here's the issue:
(bianchimatic with a 14:9sha)
It'll start and run strong for about 2 miles - can reach 25mph wot
Idles ok at stops but at about the 2 mile mark it'll start to struggle at stops, and will stall if I have to stop around 3 miles.
If I let it sit for 5 minutes , it'll start back up and run again...only a shorter distance if I have to stop.
However if I can stay above 10mph it'll run strong. Only problem seems to be when I come to a stop.
Initially I noticed that the fuel line was empty when this happened so I thought vapor lock. I put different gas cap on, even ran without a cap for a bit, then tried a new fuel filter. Same issues. Then I took out the filter altogether - same problem (except without the filter I noticed the fuel line wasn't empty).
for what its worth, the spark plug was new in the fall and hasn't had many miles on it yet. still, could be something...?
I'm stumped
Re: stalling problem, could use some help
Downhill Harvey (OFMC) /
Sounds like a condenser. To check that, when it stops running, immediately check for spark. If no spark, and it is a bad condenser, spark should return when I cools down. If spark returns, it is a bad condenser.
Scott Swope /
Thanks for the insight DH - If this rain lets up I'll try it out this afternoon and post back.
Scott Swope /
no closure on this yet Harvey - haven't had time to ride it far enough to duplicate the problem. Hoping to get at it this weekend. Just wanted to let you know - I appreciate the help
