I have changed the spark plug and Back light. cleaned flywheels points. has spark it just wont start I put gas into cylinder, nothing still. It has about 147 psi of pressure in cylinder idk if that's a problem its supposed to have 120..? Please help
Follow the Ignition Troubleshooting Chart and Carburetion Troubleshooting chart in this manual:
http://www.mopedcentral.com/images/GarelliEngineServiceManual.pdf
And the Troubleshooting chart in this manual:
http://www.mopedcentral.com/images/AmericanGarelliServiceManual.pdf
check if spark is weak or strong, yellow=weak, blue with snap sound=strong. incorrect point gap?= timing off. check carb, may be getting too much/ not enough gas. sha carb?
What should the point gap supposed to be? And what do I check/ do to the carbI think its getting too much gas the spark plug is wet when i take it out
Point gap is in the manual that was linked... between .014 and .018. I doubt you're getting too much gas, you just need spark.
wet plug = too rich check that the float valve is working properly.
