What is the clutch cable needed to repair/ replace on a Sachs motor?
Youre going to have to get creative here- i need to install a new cable. There are none that will fit without cutting/knarping, but if you get yourself some brake cable and the longer skinnier knarps that treat sells you can make one pretty easily.
This is what I did:
Its a bit of a pain. I can make you one for $15.
Thanks Funke Net!
Ill give that a try and if I cant get it, Ill commission you the 15$.
Thanks
You can substitute carb cleaner for the methyl hydrate.
