50v piston question
i see listed on treatland.tv the av7 piston kit, but it comes in 3 sizes, 38.94mm, 38.95mm and 38.97mm. which one do i need? i have a 1978 50v (30mph)
Re: 50v piston question
Downhill Harvey (OFMC) /
It might be stamped on top of the piston. Is your piston stamped anywhere?
Look on the cylinder deck - there is a letter stamped in there (A thru S) to tell you the size, piston needs to be matched.
I attached a chart
