Re: I broke the exhaust bolt that connects to the head: e50
Patrick Keaton /
The exhaust connects to the CYLINDER.The exhaust bolts do not go all the way through. Leave it together, and see what you can do with it the way it is. If you take it apart, you might crack a piston ring or two when you put it back together. The STUD bolt for the HI TORQUE - CYLINDER is [m6 x 18] and is made of steal. You need to find out if there is any of it left to grab, if not you will have to center punch it and drill it out. Easy out is an opthion. I never had an easy out work for me. Sear has a tool like an easy out, but they claim it is better, so see if that tool may help you.If you tap it, you will want to use a bottom tap.
  I broke the exhaust bolt that connects to the head: e50Topic by: Wouldntyou Wannaknow Wouldntyou Wannaknow 05/28/12 04:10PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Patrick Keaton Patrick Keaton 05/28/12 05:53PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Probably Fred Probably Fred 05/28/12 06:03PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Wouldntyou Wannaknow Wouldntyou Wannaknow 05/28/12 06:08PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Eric P Eric P 05/28/12 08:14PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Patrick Keaton Patrick Keaton 05/28/12 08:39PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/28/12 08:43PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Probably Fred Probably Fred 05/28/12 08:49PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/28/12 08:58PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Michael Thomas Michael Thomas 05/28/12 09:21PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Wouldntyou Wannaknow Wouldntyou Wannaknow 05/28/12 09:28PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Mel Dyer Mel Dyer 05/29/12 12:00PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Wouldntyou Wannaknow Wouldntyou Wannaknow 05/29/12 06:21PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Patrick Keaton Patrick Keaton 05/29/12 07:17PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Probably Fred Probably Fred 05/29/12 07:49PM
  Re: I broke the exhaust bolt that connects to the head: e50Re: Michael Thomas Michael Thomas 05/30/12 07:23AM
