Re: Getting a 1971 vespa ciao to work.
discontinuuity _ /
If the idle still isn't working try gapping the points. It should be 0.45mm or so.
If that doesn't work you probably have an air leak, maybe even a bad crank seal. Spray some carb cleaner on all the joints between the parts of the engine. If the engine speed changes you have a leak at that spot. If you're getting lots of gunk in the ignition behind the flywheel, then the crank seal is probably bad.
  Getting a 1971 vespa ciao to work.Topic by: daniel cox III daniel cox III 05/26/12 04:10AM
  Re: Getting a 1971 vespa ciao to work.Re: Emilio Gonzales Emilio Gonzales 05/26/12 05:51AM
  Re: Getting a 1971 vespa ciao to work.Re: daniel cox III daniel cox III 05/26/12 07:15PM
  Re: Getting a 1971 vespa ciao to work.Re: discontinuuity _ discontinuuity _ 05/27/12 01:59AM
  Re: Getting a 1971 vespa ciao to work.Re: Emilio Gonzales Emilio Gonzales 05/27/12 11:47PM
  Re: Getting a 1971 vespa ciao to work.Re: daniel cox III daniel cox III 05/27/12 11:59PM
  Re: Getting a 1971 vespa ciao to work.Re: daniel cox III daniel cox III 05/28/12 12:07AM
  Re: Getting a 1971 vespa ciao to work.Re: Emilio Gonzales Emilio Gonzales 05/28/12 12:37AM
  Re: Getting a 1971 vespa ciao to work.Re: daniel cox III daniel cox III 05/28/12 01:09PM
  Re: Getting a 1971 vespa ciao to work.Re: daniel cox III daniel cox III 05/31/12 09:53PM
  Re: Getting a 1971 vespa ciao to work.Re: daniel cox III daniel cox III 06/01/12 11:58PM
  Re: Getting a 1971 vespa ciao to work.Re: fallout Survivor fallout Survivor 06/02/12 09:32AM
  Re: Getting a 1971 vespa ciao to work.Re: fallout Survivor fallout Survivor 06/03/12 10:34AM
  Re: Getting a 1971 vespa ciao to work.Re: daniel cox III daniel cox III 06/02/12 08:15PM
  Re: Getting a 1971 vespa ciao to work.Re: fallout Survivor fallout Survivor 06/03/12 09:28AM
  Re: Getting a 1971 vespa ciao to work.Re: daniel cox III daniel cox III 06/03/12 09:37PM
  Re: Getting a 1971 vespa ciao to work.Re: daniel cox III daniel cox III 06/20/12 12:15PM
  Re: Getting a 1971 vespa ciao to work.Re: daniel cox III daniel cox III 07/18/12 03:41PM
  Re: Getting a 1971 vespa ciao to work.Re: ♣Slew Foot♣ ♣Slew Foot♣ 07/18/12 06:46PM
  Re: Getting a 1971 vespa ciao to work.Re: daniel cox III daniel cox III 07/30/12 09:45PM
