piston ring trouble
Nathan DeVore /
Ok I've now ordered and broke 2 47mm piston rings for the 74cc airsal kit I just got, while trying to fit the piston into the cylinder. What the hell am I doing wrong?! Is there some tool I need for this operation that I've somehow managed to glaze over in the repair manual? Any advice would help me greatly.
Re: piston ring trouble
First check the end gap on the rings by placing them in the cylinder and measuring with a feeler gauge.
When you put the rings on the piston make sure the ends are located where the anti rotation pins are in the ring groove.
Nathan DeVore /
Gah..Anti rotation pins, ok well this all seems to make sense now. I hadn't even seen those or read about them any where for that matter, but no wonder I was just sitting there struggling and snapping piston rings left and right. Thanks for the help.
theres a little pin sticking up and the hole in the ring, goes in that. you place the ring on taht, the hole goes there.
