Can the two tubes at the base of the tank be used as a main source to get fuel to the carb? Flow issues at all?
No but put them in a Y with fuel lines or you won't get all the gas out
hey, do you mean like connect the two breath nipples to each other with one short piece of fuel line ? I am about to reassemble my bike and i didn't know what to do with the two tiny outlets.
thanks for the help.
Yes connect them together with a piece of fuel line
i was thinking about cutting the nipples and welding the holes closed then grinding it smooth.
Then you won't get all the gas out of the tank and sludge can form in the other side of it
hm, good point, didn't think about that.
