i need help fixinga dellorto
mr mister /
i cant get this thing tuned. iuve got a 50cc something or other. uh. so ive got a phbg 21mm dellorto. now i got a 72cc big bore kit. big 28mm muffler, racing. 21mm intake manifold. big reed cager. ported the motor. the reed cage intake.
ok so no matter what,... its running lean. running lean. and then im like oh its runnng rich. but its running leane. its running lean. or its flooidng. too much gas is getting in and i can't cut enough air off to makeit not run. a/f mix screw, screwed in totally. so i checked my throttle cable out. its not long enough and doesn't pull up high enough. its only got a paper thin hole under it now. and it is about a penny from flooring it all the way. the slide in the middle. its like a penny stikcing out. when its floored. i guess its as goodas i can get it. so i was trying to set up the carb so i,... wasnt over idling wheni wsa trying to tune my pilot jet. well, started with 44, now 46. wondering if i should even be this high. so thoght maybe something was leaking, or gas was leaking in. not a petcock problem. vacuum is running good. i read this.
3.2.1 Selection of the needle valve size
For a motorcycle with gravity feed from a fuel tank, the fuel inlet valve size, stamped on the seat of the needle-valve itself, should always be 30 % greater than the main jet size.
In case of malfunctioning, you may find that the needle valve size is too small when running the engine at full throttle for a long stretch and that the engine rpm falls, due to the progressive weakening of the carburation.
Conversely, you may get repeated flooding in use where the needle valve seat size is too large.
yea. what? can somebodyu tell me. is that the float needle there? read all this from http://www.benelli.nl/dellorto_3_2.htm
ive got the idle at lowest i can run the motor i sit there and blip it. start it up with 0 turns out on a/f scre. it runs better. i can get lower throtle. i blip it to keep it going. so then i turn the a/f mix screw 2 turns out. start it, blip it, and set the idle. it has to be more turnsin to run. i turn in the a/f screw and can turn the idle in and get the rpms to run.
  i need help fixinga dellortoTopic by: mr mister mr mister 05/15/12 12:23AM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 02:26PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 02:28PM
  Re: i need help fixinga dellortoRe: Mars   Mars   05/15/12 03:01PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 03:02PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 03:04PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 03:05PM
  Re: i need help fixinga dellortoRe: Mars   Mars   05/15/12 03:06PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 03:10PM
  Re: i need help fixinga dellortoRe: Mars   Mars   05/15/12 03:29PM
  Re: i need help fixinga dellortoRe: Michael Cohen Michael Cohen 05/15/12 03:36PM
  Re: i need help fixinga dellortoRe: John Madison John Madison 05/15/12 03:38PM
  Re: i need help fixinga dellortoRe: Lis Pony Lis Pony 05/15/12 04:34PM
  Re: i need help fixinga dellortoRe: Fish tits Krauthamer Fish tits Krauthamer 05/16/12 07:12AM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/24/12 11:16PM
  Re: i need help fixinga dellortoRe: Michael Cohen Michael Cohen 05/15/12 04:40PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 04:44PM
  Re: i need help fixinga dellortoRe: Mars   Mars   05/15/12 04:46PM
  Re: i need help fixinga dellortoRe: Evan Parker Evan Parker 05/15/12 06:39PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 06:41PM
  Re: i need help fixinga dellortoRe: Weak-Ends Tj Weak-Ends Tj 05/15/12 10:26PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 06:42PM
  Re: i need help fixinga dellortoRe: Nick Jobbitt Nick Jobbitt 05/15/12 03:36PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 04:14PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 04:17PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 04:28PM
  Re: i need help fixinga dellortoRe: John Madison John Madison 05/15/12 03:39PM
  Re: i need help fixinga dellortoRe: Michael Thomas Michael Thomas 05/15/12 04:15PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 06:44PM
  Re: i need help fixinga dellortoRe: Eric Castro Eric Castro 05/15/12 09:11PM
  Re: i need help fixinga dellortoRe: Christian Giron Christian Giron 07/26/12 08:56AM
  Re: i need help fixinga dellortoRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/15/12 08:16PM
  Re: i need help fixinga dellortoRe: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 05/15/12 08:19PM
  Re: i need help fixinga dellortoRe: - rwc - - rwc - 05/15/12 08:29PM
  Re: i need help fixinga dellortoRe: B. ill B. ill 05/15/12 08:33PM
  Re: i need help fixinga dellortoRe: Mars   Mars   05/15/12 08:57PM
  Re: i need help fixinga dellortoRe: Dan O Dan O 05/15/12 09:07PM
  Re: i need help fixinga dellortoRe: The Reverend Defecator The Reverend Defecator 05/15/12 09:08PM
  Re: i need help fixinga dellortoRe: Sullivan & Sullivan,llp Sullivan & Sullivan,llp 05/15/12 09:28PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/16/12 05:59AM
  Re: i need help fixinga dellortoRe: Borg Resistance Borg Resistance 05/15/12 11:53PM
  Re: i need help fixinga dellortoRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 05/16/12 03:57AM
  Re: i need help fixinga dellortoRe: no eyebrows no eyebrows 05/16/12 07:16AM
  Re: i need help fixinga dellortoRe: Lis Pony Lis Pony 05/16/12 10:50AM
  Re: i need help fixinga dellortoRe: Born to be WillD Born to be WillD 05/16/12 11:09AM
  Re: i need help fixinga dellortoRe: Jared Hummel Jared Hummel 05/16/12 12:02PM
  Re: i need help fixinga dellortoRe: Mars   Mars   05/16/12 12:34PM
  Re: i need help fixinga dellortoRe: Lis Pony Lis Pony 05/16/12 02:15PM
  Re: i need help fixinga dellortoRe: no eyebrows no eyebrows 05/16/12 07:26PM
  Re: i need help fixinga dellortoRe: Noel Motzing Noel Motzing 05/17/12 03:32AM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/24/12 11:18PM
  Re: i need help fixinga dellortoRe: Aron Chaudiere Aron Chaudiere 07/26/12 10:41AM
  Re: i need help fixinga dellortoRe: Mike Price Mike Price 07/26/12 02:54PM
  Re: i need help fixinga dellortoRe: Jimbo Grand Daddy Jimbo Grand Daddy 09/14/13 05:07PM
  Re: i need help fixinga dellortoRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 05/18/14 08:16PM
  Re: i need help fixinga dellortoRe: Josiah McCoy Josiah McCoy 05/19/14 07:09AM
  Re: i need help fixinga dellortoRe: Brent Bublitz Brent Bublitz 05/19/14 09:31AM
  Re: i need help fixinga dellortoRe: Josiah McCoy Josiah McCoy 05/19/14 12:08PM
  Re: i need help fixinga dellortoRe: Mars   Mars   05/15/12 12:32AM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 02:49AM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 02:51AM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 02:29PM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/15/12 02:59PM
  Re: i need help fixinga dellortoRe: Mars   Mars   05/25/12 08:16AM
  Re: i need help fixinga dellortoRe: mr mister mr mister 05/25/12 07:23PM
