Gas tank repair/replacement
Larry Parrish /
I have a pair of 1981 Honda Express. Neither have been run since 1996. Recently, I took one into a repair shop. Everything looks fixable, except I have a good bit of rust in the gas tank. Does anyone know where I could get a replacement tank? Or is there a method that I could clean my tank?
Re: Gas tank repair/replacement
Read the wiki man, wiki!
Once you clean it up I recommend using POR-15 to coat the inside if you want to spend an extra $20.
I have the same problem but with a 78 Peugeot 102. The tank is part of the frame so no replacing it. Until I have the chance to clean it (2weeks) could i still run it with the rusty tank? Will the petcock filter it for the time be? Or should I add an inline fuel filter in addition?
Thx
get an inline fuel filter for a few buck until your able to clean it.
