Re: Peugeot 103 puch ignition coil question
Chris Heynes /
Hi, just for the record that worked just fine, except when the lights are on. Seems when the headlight and tail light and brake lights are all on, it requires too much juice and everything sort of goes kind of dim. So the result of pulling the brake is that the tail light goes dimmer instead of getting brighter (when the lights are on- works great when not). I'll screw around with the bulb, or use an LED for the brakes and see if that helps. Just tossing that out there
  Peugeot 103 puch ignition coil questionTopic by: Zach Williams Zach Williams 03/16/12 11:45PM
  Re: Peugeot 103 puch ignition coil questionRe: Glenn Kuehn Glenn Kuehn 03/18/12 02:16AM
  Re: Peugeot 103 puch ignition coil questionRe: Zach Williams Zach Williams 03/19/12 08:09PM
  Re: Peugeot 103 puch ignition coil questionRe: Glenn Kuehn Glenn Kuehn 03/19/12 11:00PM
  Re: Peugeot 103 puch ignition coil questionRe: Zach Williams Zach Williams 03/19/12 11:02PM
  Re: Peugeot 103 puch ignition coil questionRe: cheetahchrome . cheetahchrome . 03/20/12 01:49AM
  Re: Peugeot 103 puch ignition coil questionRe: cheetahchrome . cheetahchrome . 03/20/12 01:51AM
  Re: Peugeot 103 puch ignition coil questionRe: Zach Williams Zach Williams 03/20/12 11:36AM
  Re: Peugeot 103 puch ignition coil questionRe: cheetahchrome . cheetahchrome . 03/20/12 11:44AM
  Re: Peugeot 103 puch ignition coil questionRe: Dale Myers Dale Myers 04/01/12 10:04AM
  Re: Peugeot 103 puch ignition coil questionRe: cheetahchrome . cheetahchrome . 04/01/12 02:19PM
  Re: Peugeot 103 puch ignition coil questionRe: R S R S 04/02/12 12:18AM
  Re: Peugeot 103 puch ignition coil questionRe: Marvin Chan Marvin Chan 04/02/12 01:15AM
  Re: Peugeot 103 puch ignition coil questionRe: - Savwha - Savwha 04/25/12 06:49PM
  Re: Peugeot 103 puch ignition coil questionRe: Dale Myers Dale Myers 04/25/12 08:32PM
  Re: Peugeot 103 puch ignition coil questionRe: Jimbo Grand Daddy Jimbo Grand Daddy 04/26/12 01:53AM
  Re: Peugeot 103 puch ignition coil questionRe: Chris Heynes Chris Heynes 05/19/12 09:30PM
  Re: Peugeot 103 puch ignition coil questionRe: Chris Heynes Chris Heynes 05/20/12 12:11AM
  Re: Peugeot 103 puch ignition coil questionRe: Dale Myers Dale Myers 04/26/12 04:28AM
  Re: Peugeot 103 puch ignition coil questionRe: Jimbo Grand Daddy Jimbo Grand Daddy 05/20/12 12:59AM
  Re: Peugeot 103 puch ignition coil questionRe: Chris Heynes Chris Heynes 05/20/12 05:16PM
  Re: Peugeot 103 puch ignition coil questionRe: Jimbo Grand Daddy Jimbo Grand Daddy 05/21/12 05:56PM
  Re: Peugeot 103 puch ignition coil questionRe: Chris Heynes Chris Heynes 05/22/12 04:01PM
  Re: Peugeot 103 puch ignition coil questionRe: Chris Heynes Chris Heynes 06/02/12 10:31AM
