Re: Peugeot 103 puch ignition coil question
Dale Myers /
the original puch duel ignition coils setup. had the internal coil, horn with the ignition combined. blue was ignition and blue with black tracer ie.. the horn wire. my horn coil was shorting out in internally. when i hit the horn button, it shorted out the ignition like hitting the kill switch. thats why i going to run this this one. and run the brake coil setup to run the horn. and i bought the 12 volt lighting coil to run the head light and both back lights. this setup will make me run one more wire because i'm running a separate common wire from the lighting coil, the normal ground or center tap from the lighting coil will be ran to two bridge rectifiers. the yellow and green wires will also run to each of the bridge rectifiers. then the positives and negatives will be run to the regulator. then i will be able to run rear led's. that will be how my puch will be setup.
  Peugeot 103 puch ignition coil questionTopic by: Zach Williams Zach Williams 03/16/12 11:45PM
  Re: Peugeot 103 puch ignition coil questionRe: Glenn Kuehn Glenn Kuehn 03/18/12 02:16AM
  Re: Peugeot 103 puch ignition coil questionRe: Zach Williams Zach Williams 03/19/12 08:09PM
  Re: Peugeot 103 puch ignition coil questionRe: Glenn Kuehn Glenn Kuehn 03/19/12 11:00PM
  Re: Peugeot 103 puch ignition coil questionRe: Zach Williams Zach Williams 03/19/12 11:02PM
  Re: Peugeot 103 puch ignition coil questionRe: cheetahchrome . cheetahchrome . 03/20/12 01:49AM
  Re: Peugeot 103 puch ignition coil questionRe: cheetahchrome . cheetahchrome . 03/20/12 01:51AM
  Re: Peugeot 103 puch ignition coil questionRe: Zach Williams Zach Williams 03/20/12 11:36AM
  Re: Peugeot 103 puch ignition coil questionRe: cheetahchrome . cheetahchrome . 03/20/12 11:44AM
  Re: Peugeot 103 puch ignition coil questionRe: Dale Myers Dale Myers 04/01/12 10:04AM
  Re: Peugeot 103 puch ignition coil questionRe: cheetahchrome . cheetahchrome . 04/01/12 02:19PM
  Re: Peugeot 103 puch ignition coil questionRe: R S R S 04/02/12 12:18AM
  Re: Peugeot 103 puch ignition coil questionRe: Marvin Chan Marvin Chan 04/02/12 01:15AM
  Re: Peugeot 103 puch ignition coil questionRe: - Savwha - Savwha 04/25/12 06:49PM
  Re: Peugeot 103 puch ignition coil questionRe: Dale Myers Dale Myers 04/25/12 08:32PM
  Re: Peugeot 103 puch ignition coil questionRe: Jimbo Grand Daddy Jimbo Grand Daddy 04/26/12 01:53AM
  Re: Peugeot 103 puch ignition coil questionRe: Chris Heynes Chris Heynes 05/19/12 09:30PM
  Re: Peugeot 103 puch ignition coil questionRe: Chris Heynes Chris Heynes 05/20/12 12:11AM
  Re: Peugeot 103 puch ignition coil questionRe: Dale Myers Dale Myers 04/26/12 04:28AM
  Re: Peugeot 103 puch ignition coil questionRe: Jimbo Grand Daddy Jimbo Grand Daddy 05/20/12 12:59AM
  Re: Peugeot 103 puch ignition coil questionRe: Chris Heynes Chris Heynes 05/20/12 05:16PM
  Re: Peugeot 103 puch ignition coil questionRe: Jimbo Grand Daddy Jimbo Grand Daddy 05/21/12 05:56PM
  Re: Peugeot 103 puch ignition coil questionRe: Chris Heynes Chris Heynes 05/22/12 04:01PM
  Re: Peugeot 103 puch ignition coil questionRe: Chris Heynes Chris Heynes 06/02/12 10:31AM
