Honda camino wiring quiz
trying to sort out this camino wiring. so far..
From handlebar switch:
Blue brown and white
goes to double filament front light
Horn grey
cut off switch doesn't work
ONly four wires from switch one is horn earth.
Above left crank:
Two blue wires on earth screw.
From this loom near left crank:
Blue not connected
Red connected
Green connected
behind this loom still left side near crank:
Red wire not connected
Black white stripe connected goes to black rectangular box on right side of bike in between chain what is it?
ONE terminal not used from black white wire from engine
Pink not connected from engine ??
GReen run up to fork
Blue runs down from it
Blue run up back in loom to frame out of this red and brown goes to speedo?
Green and white stripe wrapped to pink and black stripe this is spaded turns into pink goes back to frame.
brown and white stripe exposed wire next to it this runs into spade behind horn and turns into brigtdp green goes back into frame
Yellow green stripe
Green
Red
Brown
all from loom From frame near fork
Red and brown to speedo
Green to two terminals one to horn and green back to frame
another loom popping out at fork...
Brown been cut
Blue been cut
Light grey been cut ??? what are these?
Blue
Bright green to brown white stripe
Pink to pink white stripe at wired up on handlebar been twisted together
White .. to brown white stripe
green comes from frame
Goes under handlebar some weird small heatsink with fins what's this!!!!!!
Out of this comes blue and white stripe
Back to frame top terminates to spade male
please help!!!
Re: Honda camino wiring quiz
copy paste from your Other thread-------------------------------
Look on the forks, the middle column should have the date on it. I am guessing your CDI?
You make it sound like a lot of wires, and your post is confusing. What are you trying to do? Rebuild the whole harness because yours was chopped/didn't exist?
Build a mspaint diagram E.G.
^I'm having wiring problems too with some little St110y dirtbike that was given to me, NO CDI or Ignition coil? its really weird not knowing how its supposed to be put together, so I am guessing thats the problem your having, you just need to know what goes where.
Downhill Harvey (OFMC) /
If your Camino is anything like a Hobbit, that'll mean it's a Honda. If the wiring is stock, and you have a diagram for your bike, Honda seems to do it this way: with male and female connectors, you just plug a male wire into the female connector, and make sure the colors match.
Again, if the wiring is unmolested, male to female/matching colors.
There's 21 wiring diagrams in the factory manual. You'll have to figure out what diagram matches what color the wires are, and what they're connected to (brake switch, or the kill switch, horn, etc).
http://www.mopedriders.org/html/manuals/honda/pa50sm/honda83pa50manual.pdf
I highly doubt your Country's regulations, coincided with USA regulations, so our wiring probably won't work,
the brake light switch works. horn works. will have to test wiring for voltage, maybe there was an ignition switch on there, or indicators? the fin thing is a rectifier I have learned. will try and up some pictures.
