Honda camino wiring quiz
puch lover /
trying to sort out this camino wiring. so far..
From handlebar switch:
Blue brown and white
goes to double filament front light
Horn grey
cut off switch doesn't work
ONly four wires from switch one is horn earth.
Above left crank:
Two blue wires on earth screw.
From this loom near left crank:
Blue not connected
Red connected
Green connected
behind this loom still left side near crank:
Red wire not connected
Black white stripe connected goes to black rectangular box on right side of bike in between chain what is it?
ONE terminal not used from black white wire from engine
Pink not connected from engine ??
GReen run up to fork
Blue runs down from it
Blue run up back in loom to frame out of this red and brown goes to speedo?
Green and white stripe wrapped to pink and black stripe this is spaded turns into pink goes back to frame.
brown and white stripe exposed wire next to it this runs into spade behind horn and turns into brigtdp green goes back into frame
Yellow green stripe
Green
Red
Brown
all from loom From frame near fork
Red and brown to speedo
Green to two terminals one to horn and green back to frame
another loom popping out at fork...
Brown been cut
Blue been cut
Light grey been cut ??? what are these?
Blue
Bright green to brown white stripe
Pink to pink white stripe at wired up on handlebar been twisted together
White .. to brown white stripe
green comes from frame
Goes under handlebar some weird small heatsink with fins what's this!!!!!!
Out of this comes blue and white stripe
Back to frame top terminates to spade male
please help!!!
