Re: bog under low rpm load, WOT fine
Burns Hudson /
Thanks guys, I will check for air leaks again and tighten up my exhaust some more.
Then if I still have the problem, I will downjet the idle and main significantly to see if that changes anything, then if it does I will jet back to stock and buy a range of jets and work my way slowly down.
My carb is crazy sputtering gas out - I smelled like I dipped my pants in gas when I stopped working yesterday, so I am guessing that it is carb-related.
