Re: bog under low rpm load, WOT fine
Born to be WillD /
THIS IS MOST LIKELY A COMPRESSION PROBLEM. RINGS BROKEN OR IMPROPERLY SET IN, HEAD NOT TIGHT ETC. COULD BE TIMING AND JETTING ALSO, MIXTURE SCREW AFFECTS LITTLE, TRY PLAYING WITH SOME OTHER MAIN JETS AND SEE WHAT CHANGES.
THE "with the wheel off the ground, the rev up is great
With any load at all, it barely moves at any throttle position" SYMPTOMS HEAVILY POINT TOWARDS COMPRESSION THOUGH.
