bog under low rpm load, WOT fine
Burns Hudson /
I just got a kit and carb and all that jazz, PHBG.
With the wheel off the ground, the rev up is great
With any load at all, it barely moves at any throttle position
If I scoot it along by foot or down a small hill, eventually I can get going under motor power and once the pipe kicks in I am doing 40+ uphill.
Idles great, but is sputtering gas out of the filter side, the whole inside of the carb looks to be completely saturated in gas when it is running
I have adjusted the mixture screw, but it doesn't seem to change any of the symptoms. I dropped the needle all the way down (clip at top, leanest it can get)
Is this a pilot jet problem, or is there something I am overlooking?
The jetting is all stock for the carb, I didn't see any numbers on any of the jets. (edited)
