qt50 carb oil line removal
Howdy
I'm trying to get my carb off for a cleaning. I was expecting the oil line to be attached to the pump with a nut, but I find that it is held on both ends by a clip. What is the best way to get the line off with out damaging it? Should I just grab on and yank it or is their a proper way to get the hose of?
Thanks for any help.
Terry
Re: qt50 carb oil line removal
matt boda1nz /
why are you trying to remove the hose from the pump?
Terry McNamara /
Well, I was just following the shop manual. It shows a nut on the oil pump end of the line and says to remove it there and plug it to prevent leaks.
As I am looking a little closer, I see these clips just slide around the hose to help hold the line tight to the barb. I can get it off at the carb no problem after all. Much easier.
matt boda1nz /
just plug the carb end of the line..
don't touch the pump.
matt boda1nz /
better yet, just take the pump off, remove the gear on the pump, put the oil pump back on, plug the oil line inlet on the carb.. and premix.... 40:1
Gruff "(OFMC)" - /
If all your trying to do is take the carb off... the line just slips off on the carb? WTF!
