Well, I was just following the shop manual. It shows a nut on the oil pump end of the line and says to remove it there and plug it to prevent leaks.
As I am looking a little closer, I see these clips just slide around the hose to help hold the line tight to the barb. I can get it off at the carb no problem after all. Much easier.
