Re: Puch Maxi cleaning gas tank HELP!!!
Sneaky Pure /
If you really needed a quick and permanent fix, then you would've read my first post, done your research, and then realized you are doing too much work to get too little of a result.
Yes, clean your tank out.
Then seal it.
There are a bunch of brands, however, you should really stick to something like caswell or the por15 tank sealer.
The sealer takes 1 or 2 days to dry depending on temperature, and then the inside of your tank will never be rusty again because the sealer is a hardening coat on the inside.
google helps
  Puch Maxi cleaning gas tank HELP!!!Topic by: Michael Burke Michael Burke 06/16/11 08:20PM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: Reggie Green Reggie Green 06/16/11 08:31PM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: Michael Burke Michael Burke 06/16/11 08:52PM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 06/17/11 01:19AM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: Dwayne Hoster Dwayne Hoster 06/17/11 02:15AM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: David Coddaire David Coddaire 06/17/11 10:12AM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: Sneaky Pure Sneaky Pure 06/17/11 02:49PM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 06/17/11 02:50PM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: Michael Burke Michael Burke 06/21/11 03:58PM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: sir thaddeusforemen sir thaddeusforemen 06/22/11 08:17PM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: Michael Burke Michael Burke 06/23/11 04:30PM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: Janius Eyerman Janius Eyerman 06/23/11 08:20PM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: Stephen Keller Stephen Keller 06/23/11 08:25PM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: Terry McNamara Terry McNamara 06/24/11 03:45AM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: Michael Burke Michael Burke 06/25/11 04:13PM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: sir thaddeusforemen sir thaddeusforemen 06/27/11 07:13AM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: alan novi alan novi 06/30/11 10:09AM
  Re: Puch Maxi cleaning gas tank HELP!!!Re: Sneaky Pure Sneaky Pure 06/28/11 02:05AM
