Re: Exasperated by puch maxi - runs good 1/4 throttle, dies above 3/4
Sneaky Pure /
just to be careful:
use carb cleaner to spary head, base, and intake at idle to make sure you have no air leaks.
on your carb, make sure your float is set correctly and engaging / disengaging properly.
Get a new plug, run on WOT for a few minutes....shut the bike off at WOT, pull over and do plug test. What color is it?
That is going to tell you whether you are fine, need to up or downjet.
If you are fine at WOT, then you mess with your needle so that you can fix your other ranges.
