no problem dude.
looks like a qt50 carb..
replace the bowl gasket while you are ordering stuff. might as well.
and as a tip, and unrelated to your leaking..
get some moldable, gas safe, putty epoxy and plug up the carb drain on the bottom of the carb bowl. push the epoxy putty in there until you know you have enough in there. i have had two qt50s and they both became issues as far as leaking. i have never needed the drain spout.
