Re: gas leaks out of this hole. what is it?
matt boda1nz /
gas can't get into the carb if the float and float needle work correctly.
if the float and float needle work correctly, you won't have this problem.
bowl fills up pushing float up, needle seals off the gas. = no gas = no drip
