Re: Yamaha QT50 Turn Signal Problems
Steven Lowman /
ive fixed many of these bikes....1st charge the battery up with a charger...check water level in battery.......but in the front the turn signal relay sounds like it is bad.....you also could have the wiring wrong in the front......pull off the front platic cover and make sure all the wires are connected...they are color coded and should match up..they may have just come loose....also remove the covers on the blinkers themselves....you may have a couple of bad bulbs.....sorry cant be much more help without seeing the bike .....steve
