Maxi Head Leak
Brenan Chambers /
Serious head leak, you can actually see smoke puffing out of it. I had a friend mill down the head a while back, worked just fine until recently. Something must be warped, its done. I tried it with 2 different heads, a milled one and one new, same problem.
So, should I even bother trying to make a repair or should i just replace the whole cylinder, get a whole new kit. Also, if kitting is the best option, which should I choose?
Thanks
Re: Maxi Head Leak
Kits depend on your level of tuning.
Re: Maxi Head Leak
John Joedicke /
Anneal the metal gasket and then re torque.
Re: Maxi Head Leak
Oh yeah, what John said.
Also make sure that you torque evenly when you install the head. It should be a gradual process so that you don't over torque anywhere.
