Yamaha YG1 Battery / Fuel/oil ratio
Nathaniel Warner /
Hi, does anybody know where to find a 6 volt battery for a Yamaha YG1? Also does anybody know what fuel to oil ratio to use on the yamaha yg1? I think I read somewhere that it should be 20:1.
Thanks (edited)
Re: Yamaha YG1 Battery / Fuel/oil ratio
it should be 20:1. If you run synthetic you could probably go a little less.
Also for your battery, you can go to a battery store and just by a small one (that is also sealed) that will fit in the side compartment. They won't be as tall but will still fit.
I own the 66 yamaha yf1 (yj1) in the photos and they are similar to the yg1
