So...tell me if this would be proper.
I'm thinking of wiring in an external condenser on my motobecane sebring, MO2 engine. On my av7 motobecane, the external condenser is run off the line that would normally run to the kill switch. The wiring appears to be similar on the sebring, so (you geniuses chime in here) would I cut the red wire that goes to the run/off switch on my handlebar, splice in the external condenser and give it a solid ground, and then be ok? All the damn wiring is wrapped up in shrink tubing and can't tell what goes where.
Does this seem right? I'm guessing I'll lose my horn if I do this, but I never use my stupid horn anyhow. I can yell louder than it beeps.
