Re: Puch only running with choke
Christopher Wells /
Vincent Mills Wrote:
> spray down with carb cleaner anywhere you could
> have and air leak ie intake, around cylinder head
> etc. that will quickly tell you if thats the
> problem
Sounds like an air leak. Spray it down with carb cleaner if it stalls then you have an air leak. Tighten everything down and repeat, if it still stalls then get a new gasket set.
