Sticking carb and or air leaks should be your first check.
However, just don't tighten things to tighten them. Everything has a specific toque setting. For example, if you over torque your head bolts, you are potentially change your squish zone (which changes how your engine runs).
Clean your carb. Check to see that the slide is not sticking. Make sure your cable isn't pulling the slide up at idle when it shouldn't be (aka your cable is too tight).
You can get it running and quick spray around with carb cleaner to also see if you have an air leak.
those are a few things to consider.
