i assume it is a problem with the cdi.
i have a a35 with airsal 70cc kit
stock carb and intake and proma gp pipe
this set up has been running flawless for 5-7 years(not consistantly i rode it 2 or 3 years let it sit for a year or two then rode it for a year)
everything has been fine. no problems at all. then recently i had this issue:
at low to mid rpm's i am fine,running good
when i open up the throttle it sputters a bit then dies to a complete stop. but when i kick it it will start back up.(and run low to mid throttle)
when the engine "dies" i try to give it a little or alot of throttle with no response(coasting to a stop).
i tried replacing the plug.
ive tried replacing the fuel.
it this my cdi going bad?
is this a sign of my compression going bad from riding this kit this long(and hard)?(rings going bad?)
actually....i think i checked the compression. i guess i'll double check.
if the cdi is going bad, you dont fix it,you replace it.....right?
it was a points setup then about 2 or 3 years into having the kit i upgraded to the cdi.
could it be just my cdi box going bad?
i dont want to buy all this stuff to do trial and error,if i dont need to.
i love these tomos bikes, and i can handle most complications...but this has got me stumped. i know little about cdi ignition systems so i am blaming it. help me. pahleese
