Has anyone separated the fork legs from the fork tubes on Vespa Grande forks? I don't see how to get them apart. Any help is greatly appreciated.
look inside the bottom leg there's am allen screw you need to open and then just pull off the leg
No externally accessible allen screws on Grande forks. Anyone else??
bump, also looking for info on this. Also, are grande forks are hydraulic, no? so i should fill up the legs with fork oil through the bolts on the top, right?
Grande forks are NOT hydraulic. Don't fill them with oil!!
i knew it! i had like three people tell me they are
I just tore a set of those apart... Just turn the legs. The spring ends are the attachment points.
Like slinker said, they un screw. Takes amout 1 1/2 turns
